420HP Merc vs Marine Power 330Hp
I just spun a main bearing in my 420HP 454. I have a virgin Marine Power 330HP 454 that is not being used. I'm thinking about swapping the top end of the 420 over to the 330 engine. I do know that the 330 engine has 4 bolt mains. So my question is, would the 330 engine have the 7/16-rod bolts, steel crank and forged pistons like my 420 supposedly does? If not do you think that the 330 engine will hold up ok?
Re: 420HP Merc vs Marine Power 330Hp
If it's the same as mercs 330 build:
No, 3/8"
steel crank
No, Nodular iron
and forged pistons
No, cast and they'll be lower compression
Yep, as long as you keep the rpms reasonable. 5000 rpm is pushing it.
No, 3/8"
steel crank
No, Nodular iron
and forged pistons
I suspect you might be asking for trouble. I know that having a "spare"motor is nice, but as already posted, I think the differences are many. I would rebuild the 420....
The 330 engine is about a 1991. It has been setting up since 1995. It's in a 3/4-ton 4X4 truck that had only about 20,000 miles put on it.
