Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 9 of 9
  1. #1
    Registered JS232's Avatar
    My Boats:
    2004 Baja 275 Boss
    Join Date
    Mar 2003
    Location
    Montreal,Quebec
    Posts
    1,022
    496HO on ear muffs… What’s the trick?
    I know some 496 owners are experiencing problems circulating water in the engine while the boat sits on the trailer. A mechanic told me that 496 cooling circuit design is not ear muff friendly and may need some sort of a pump to force water in the drive… Things seems worst when the block as been pressurized with the hand pump. In May, I had to get the boat at a ramp in the water so I can finally see water out from the exhaust!
    What’s the trick?
  2. #2
    Gold Member Gold Member Dave M's Avatar
    My Boats:
    2017 30 Concept, 300 Verados, Superboat Y2k and 24OS (sold)
    Join Date
    Oct 2000
    Location
    LaPlata, MD, USA
    Posts
    5,149
    Re: 496HO on ear muffs… What’s the trick?
    I haven't had any trouble running mine on the hose. I use the merc muffs that have the rod that goes through the water passage to the other side. Maybe you don't have enough water pressure at your house?
  3. #3
    My Boats:
    2003 Nordic Rage
    Join Date
    Jan 2003
    Location
    Castle Rock, Colorado
    Posts
    112
    Do you have a Bravo1x with the low water pickups? I do and I use the muffs but I need to put a piece of duct tape over the low water pickups on the front of the bullet to make sure the pump gets as much water as possible. Just don't foget to take the tape back off when your done! But I'll admit that I think it's still has marginal water pressure.
  4. #4
    Registered Macklin's Avatar
    My Boats:
    36 Concept w/ Merc 250 EFI Smokers
    Join Date
    Dec 2001
    Location
    Virginia Beach
    Posts
    1,896
    No problems here either....except one time I got distracted and forgot to turn the hose on.
    Try duct taping the low water pickups on the bullet. Probably necessary if you don't have good water pressure. I use the Merc muffs too. I also rev up to 1500 which really helps get the water flowing.
  5. #5
    My Boats:
    2004 Baja 275 Boss
    Join Date
    Mar 2003
    Location
    Montreal,Quebec
    Posts
    1,022
    Quote Originally Posted by Dave M
    I think We have a clue here... : "merc muffs that have the rod that goes through the water passage to the other side"
    My muffs are generic and have no rod. My setup is probably not tight enough around the water passage. I'l try those. Yes, I have always taped my low water pickup.
    Thanks guys.
  6. #6
    My Boats:
    Join Date
    Oct 2000
    Location
    LaPlata, MD, USA
    Posts
    5,149
    Quote Originally Posted by Macklin
    LOL! I did the same thing once. I'm standing there saying why the phuck isn't any water coming out the tips? OH NO!
  7. #7
    Registered GOODT's Avatar
    Join Date
    Apr 2005
    Location
    KENT ISLAND, MARYLAND
    Posts
    2,675
    If You Pumped Up The Block The Pump Will Not Pump ! Cant Get Any Vacum To Pull The Water
  8. #8
    My Boats:
    2004 Baja 275 Boss
    Join Date
    Mar 2003
    Location
    Montreal,Quebec
    Posts
    1,022
    Quote Originally Posted by GOODT
    Stating you have to get the boat back at the ramp once it has been air pumped?
  9. #9
    Forum Regulator VIP Member Sydwayz's Avatar
    My Boats:
    17' Speedliner Cat & O.P.B.
    Join Date
    May 2001
    Location
    Worldwide
    Posts
    21,569
    I'd just pulled off the water pump assembly and the feeder hose, and made my own t-fittings for a fresh water flush kit to the directly to the garden hose. I hate using muffs with a passion. It was a ***** to do, especially on a twin engine setup, but totally worth it in the long run.
    When I did use muffs though, I just had the generic ones from Boater's World, rectagular on each side of the upper water pickups, tape off the LWP. Make sure you rotate them (with a little bit of WD40 to lube it) so the rectangular muff is verticle in line with your verticle upper water pickups. You may also want to Y two garden hoses together toward your outdrive to provide more pressure to your drive.
Similar Threads
  1. ear muffs
    By rtaylor in forum General Boating Discussion
    Last Post: 08-04-2008, 04:12 PM
  2. Best round ear
    By FASTERDAMITT in forum Prop Talk
    Last Post: 12-16-2005, 08:52 PM
  3. New round ear Hydromotive
    By JasonSmith in forum Prop Talk
    Last Post: 11-23-2005, 06:39 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2017 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
