OffshoreOnly Boat Classifieds Sale
Go Back   Offshoreonly.com > Technical > General Q & A
Register Upgrade/Renew Membership Forum Rules Search Today's Posts Mark Forums Read
OSO Sponsor
NorTech
OSO Sponsor
NorTech
Advertiser
Advertiser
Thread Tools Search this Thread
Old 11-23-2005, 07:40 AM   #1
Question props tarnished/key west water?
Spent 5 days in key west,boat stayed in the water like everyone else's.The props and anything stainless have a gray tarnish on them.I m thinking salt deposits?Anyone know how to clean it off/
plumbers crack is offline   Reply With Quote
Old 11-23-2005, 07:46 AM   #2
'77 Martini 7 Meter
Re: props tarnished/key west water?
"Hammerhead" makes an excellent product for use on stainless or aluminum. Even works well on stubborn stains on your fiberglass hull. (but you will have to re-wax) --- Jer
jpclear is offline   Reply With Quote
Sponsored Links
Old 11-23-2005, 07:49 AM   #3
Throttle Up Propellers Manufacturer
This is very common for Key West. There are a couple different ways to remove the white coating.
The quickest way is to use muriatic acid, just pour it on and rinse if off. You can also use some of those house cleaners like CLR but they work slowly.
Matt
throttleup is offline   Reply With Quote
Old 11-23-2005, 10:04 AM   #4
Talking Re: props tarnished/key west water?
THANK YOU,bought a product named salt away $12.00 a bottle maybe I will spray on and see what happens?How about on off bottom cleaner/It is an acid but not muric.
Old 11-23-2005, 10:58 AM   #5
Boating, four wheeling, electronics
Toilet bowl cleaner. The yucky smelling blue stuff.
Wear gloves.
No elbow grease required.
Pesky Varmint
Pesky Varmint is offline   Reply With Quote
Old 11-23-2005, 02:46 PM   #6
lime away, get the same thing at havasu white coating on everything,lime away too it right off
JJONES is offline   Reply With Quote
Old 11-24-2005, 03:40 AM   #7
1988 Bullet
Quote:
ON/Off is muriatic acid. If your going to use that...go to a harware store & buy a gallon of it. ALOT cheaper. Carefully put it in a spray bottle & try not to breathe in the fumes. Eventually the spray mechanism will deterioate.
cig1988 is offline   Reply With Quote
Old 11-24-2005, 09:32 AM   #8
boatless and on the prowl
none
i use toilet bowel cleaner...squirt on let sit for few minutes, hose/wipe off, spray with WD and done...i use SNO BOWL
berns29scarab is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Trackbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
OSO Bobthebuilder to go for Key West - Cancun - Key West record ( for Jennifur) Bobthebuilder General Boating Discussion 656 01-03-2010 01:38 PM
Sunset Key(key west).... Shorgasm General Boating Discussion 6 06-14-2006 05:26 PM
Water effects Key West-Keep abreast gdfatha General Boating Discussion 2 10-30-2005 03:57 PM
Key West water TYPHOON Offshore Super Series (OSS) 6 10-29-2004 07:18 AM
Tarnished Fastech emblems boatinbill Formula 3 02-23-2002 05:20 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright 2008 OffShoreOnly. All rights reserved.
