Hydraulic Outdrive Lift / Stand
I've used and engine hoist with a small cable loop many times for alphas, and I've also used the quadrunner jack with a homemade outdrive stand bolted to it. Either one works as well as the other, and cheap too, if you already have them hangin' around the garage anyway.
This one looks great:
http://www.woodyeng.com/
I haven't got one myself though. But I am considering it.
That does look nice but A) dont see an angle adjustment and B) dont see a way to adjust angle, which will make it a real apain tohang the drive...canstill do if you pry the bell housing up but the yard arm has the adjustment so y make life harder then it has to be ????
