Gen V or VI Mechancal fuel pump >
Old 08-22-2007, 04:23 PM
I have the KE pump upgrade that CP sells, with 1/2" lines, and a big filter my fuel pressure still drops from 6.5 to 3 psi at WOT. I am a little unsure if you get any improvement over stock except for the "bling." The valves in the stock pump bottom and the KE pump look the same to me. I can't really say that the KE pumps are better/worse than stock because I never checked fuel pressure with a stock pump, but it did feed the engine for years without a lean meltdown.
Old Navy is offline
Old 08-22-2007, 05:49 PM
Emerald Coast of Florida
Panic Button's Avatar
After unscrewing the screws, the diaphram is connected to the base of the pump. With 3psi pressure on my old pump I think the diaphram is shot and needs to be replaced. Just need to know how to change that or the arm.
Panic Button is offline
Old 08-22-2007, 06:27 PM
If the diaphram is bad you will get a lot of gas in the 1/4" vent hose and/or the oil sump for the pump arm ecentric. I have not found a way to get at the pin to remove the diaphram and rod from the arm.
Old Navy is offline
Old 08-22-2007, 07:30 PM
AIR TIME's Avatar
go with a black holley elc pump and be done.
AIR TIME is offline
Old 08-24-2007, 06:59 PM
Changed out the pump, no gear oil in the reservoir and the spring under the arm was broke, the other pump was 1/2 full with gear oil. Both now at 8psi. Also ordered 2 Holley blacks, they should be in next week…
Old 08-24-2007, 08:05 PM
kaama82's Avatar
Do NOT buy a Holley black electric pump. I had those on my Scarab, One pump a season, after 3 seasons went back to mechanical. No problems now.
kaama82 is offline
Ran-Dom 32
25
04-11-2008 05:28 PM
Craig B
4
06-16-2007 08:42 AM
StrikinLightnin
10
01-08-2005 12:30 AM
ripride1
7
05-07-2003 11:01 AM
Quick Reply: Gen V or VI Mechancal fuel pump
