Holley Gurus.... a question >
Old 12-25-2005, 05:46 PM
SORE MEMBER
Wobble's Avatar
Default Re: Holley Gurus.... a question
Originally Posted by amer3
dominator manifold and carb. Well worth the bucks, but not USCG legal of course.
that not true dominator comes uscg aproved
The proform main body and billet throttle plates are not USCG approved
Wobble is offline
Old 12-25-2005, 07:12 PM
hpy540's Avatar
Originally Posted by horsepower1
What list number Holley is it? and is it an HP series? Are you running any power valves? RPM engine spins light on fuel? get me a little more specs and I can place you right where you need to be. Thanks,
Dean Gellner
6.5 PV on front and back 89 front jets and 95 back
carb number 80330
i was spinning 5600 with no fuel and it was still pulling but slowly (94 mph gps w 2mph downstream current) i am running a 1.36 drive and a 27 pitch mirage that has been shaved quite a bit but never dialed to the boat i have to rering this spring and i am making a few changes. I was running 5400 with 7 people in the boat only doing 80 and it was topped out. it had no more. This is the time i melted the three pistons..... I had a distributor go bad. I have since replaced the dist. I know the proform body is not USCG approved. the main difference is the vent tubes and the pilots and a small plastic/uhm piece around the choke rod on the top of the carb. And sealed throttle shafts to prevent fumes from escaping in the bilge area. So for the sake of argument i am not running a hatch cover......
I am thinking about at least cutting the choke horn off.....
Roller hyd cam and 629 lift with 236 and 244 dur i cant remeber the Lsa right now.
hpy540 is offline
Old 12-25-2005, 08:37 PM
I would put the body on the carb, it's cheap enough, and is a hell of alot easier than cutting the old one. You should definately square jet that carb with the power valve in the rear. I would go to 92 square and start going fatter 2 jet sizes at a time. We ended up with 93 square with power valves on our drag cars. They were 650 hp 468's on 93 octane. Don't waste your money on a Dominator. We put one on those motors and gained nothing on the track, and they spun 7500 rpm.
Monkey Spanker is offline
Old 12-26-2005, 07:58 AM
hpy540's Avatar
Ok so what about the differnce in throttle plates? And can a person use the 950 proform body with the rest of my carb parts?
hpy540 is offline
Old 12-26-2005, 10:44 AM
I checked out proforms website, and heres what I see. The 67108C main body is the same one used for 850 and 950 carbs. The throttle plate assembly is what makes the 950. The fact that is has the thinned shafts and button head screws make the 850 body flow 950. You will only have to use the 67108C body on your baseplate. I usually take the baseplate apart and thin the old shafts myself with a die grinder and put them back in with locktight on the threads. But once again, the thinned shaft kit is so cheap and simple to install, why not spend another 100 and have a real nice trick looking carb that flows great cfm? Heck a nice looking boat like that DESERVES a great looking carb.
Old 12-26-2005, 11:04 AM
SORE MEMBER
Wobble's Avatar
Be sure and tiewrap or glue on all the vacuum port boots and it is also a good idea to locktite any screws that can drop into the intake.
The last post in this thread shows the proform base plate http://www.offshoreonly.com/forums/s...75#post1315475
Wobble is offline
hpy540
5
10-16-2006 10:26 PM
Dreaminbig
06-27-2004 06:27 PM
formula31
19
04-02-2003 01:18 PM
formula31
4
02-19-2003 04:45 PM
Quick Reply: Holley Gurus.... a question
