Exhaust help please >
Exhaust help please
Exhaust help please
Old 12-29-2005, 10:20 AM
Default Exhaust help please
I am working on an 84 Mercruiser V8. I stroked it to a 383 last year am running 10:1 compression with Sportsman II heads and a fairly big Comp cam (don't have the numbers on me). anyway, I want to hear it! I have the factory center rise manifolds and 3" Y pipe. I purchased a pair of Corsa's diverters, but can't really figure out what else I need. I'm pretty sure I need to change my y-pipe out to the newer style 4" pipe (which means pulling the engine, but whats 1 more time). Do I also need different risers? Which ones? What year boat do I need the Y-Pipe off of? My buddy has some 4" tips for me and probably some 4" hose. I'm not really looking as much for performance as just sound, and since I pull the kids on tubes alot, I definately want the diverters so I can turn the noise off. Any help will be appreciated.
thsorens is offline
Old 12-29-2005, 10:40 AM
Pat McPherson's Avatar
Default Re: Exhaust help please
You should not have to change the Y pipe.
There is a molded rubber coupling/reducer available to go from the diverters to the Y pipe.
I had them on a 4" risers and elbow to the Y-pipe before I went to through hull exhaust. I may still have them, I'll check, if I do there yours for the cost of shipping...
You will also need the 4" risers if you don't already have them...
Patrick
Pat McPherson is offline
Old 12-29-2005, 11:05 AM
That would be awesome thanks! Let me know, I can paypal you the shipping. Not pulling the engine again would be a bonus! With my current risers which I'm pretty sure are 3", the diverters angle down so much that there wouldn't be room for a 4" to 3" coupler between the diverter and the y-pipe, but I'll bet a 4" riser would straighten that out. Do I just get a stock 4" riser off of a newer boat or do I need some aftermarket riser?
Thanks again!
Tom
thsorens is offline
Old 12-31-2005, 12:24 PM
Big Block Billy's Avatar
If you do pull the engine, try to get the newer y-pipe , it is bigger, and has better flappers in it. They are all over the place and can be had new for $100. Yup You need the 4" elbows. Try spots1994's ebay auctions, he has new merc ones for $108.00 ea. I would advise using the New Merc ones because they are galvanized and powder coated and are way better than aftermarket crap. BBB
Big Block Billy is offline
Old 12-31-2005, 04:08 PM
I did that swap out last year......smallblocks......changed out the stock Merc Silent Choice to Corsa Electric......had to cut the stainless diverter pipe in two places (each diverter) to get them to fit.......didnt know there were two different size y pipes......I wouldnt pay $200 for new risers..... Id put my money into some new Revolution Marine manifolds for a grand and have all new 4" stuff.....take 100lbs off the back of the boat and more performance..........your 1984 exhaust is probably ready to go (fail internally) and lunch your nice engine.......doug
pullmytrigger is offline
Rage
41
02-18-2007 09:42 PM
wkd1
9
07-28-2005 10:41 AM
sonic28
6
01-29-2004 06:52 AM
treatj24
5
01-18-2003 10:35 AM
CAP071
Sunsation
5
04-23-2002 04:42 AM
Quick Reply: Exhaust help please
