what is the ideal water temp for a hi po n/a engine?
Re: what is the ideal water temp for a hi po n/a engine?
Originally Posted by mrhorsepower1
Running the water temp past 160 you will lose actually lose horsepower. Dean Gellner
Dean, would you please elaborate on that a bit for us? I assume you found this out from dyno testing I take it? Thanks for your input.
Yes Mark,
Depending on what compression ratio the engine is the loss of horsepower will vary. We have played around with this alot on the dyno in many different types of engines. On A 9.5:1 "B" class race marine engine from 140 to 160 we lost 4-6 horsepower on average without changing anything. In a pleasure boat application - will you tell the difference? Most likely not. But for those who are always looking for a little bit more, which is what we are after, thats 8-12 HP between 2 engines. Every little bit adds up. When I ran IHRA Pro Stock we would run the water temp at 100-110 degrees leaving the starting line. The engines are very high compression and the higher water temp would create higher combustion chamber temps thus losing HP.
Dean
Dean
Originally Posted by ratman
was wondering what water temps you guys with larger hi po n/a engines are running for water temp, thx ratman
Originally Posted by TylerCrockett
We also run our engines 110- 130 also it keeps the cylinder temps down and we make more power also. We also use a oil thermostat on all our engines to keep the oil temp above 190 and the condensation out. Tyler
Okay Dean and Tyler---I appreciate the input/info and it was a very good question that was asked by Ratman. I was asking because I am running a 160* water thermostat in my naturally aspirated 9.5 comp ratio engines, but they actually run around something like 170*-180* which I thought might be a little too warm,---but I didn't really know and was thinking of replacing them with something like a 140* or lower thermostat instead. Heck, I don't even know what the next lower temp thermostat is even made or available below a 140* thermostat! (???) Anyway, I was just curious about your findings and I am more concerned about the heat or running with too high of water temps than HP loss, but then it sounds as if I will be gaining vs losing HP----but like you said Dean, not enough to really make a difference in the speed of my boat.
Just as a side note my engines also have some Keith Eickert HP-6 size "thermofilters" (oil thermostats) that have a 212* oil thermostat in them and seem to work very well with the set-up I have.
Anyway, thanks again for your input (Dean and Tyler)---it was very helpful.
The 212 thermostats are just fine. Go to 140 water stats and it should drop your running temp down to about 150-160 degrees. The other question I have for you is what type of water picks/drives are on the boat? and what water pressure do you have at WOT? Thanks,
Dean
Dean
I run cross overs with no thermostat. 540 CID with 9.75 to 1 CR. Water temp is consistently at 100 - 130. Hard runs will get it up to 150 - 160. My concern is oil temp. At cruise it gets to about 150 - 170. Takes a long hard run (5 min at 4500+ RPM) to get the temp over 210 (not much fun for passengers if it's rough). Should I be running oil thermostats? Is the only purpose of getting oil hot to cook off condensation? I've mentioned oil thermostats to my builder before and he seems a little hesitant (says they are not needed).
Water pickups are through hull. Water PSI is 2-4 at idle, 10-12 at cruise and 18-20 at speed. Coolers are bell housing type and seem to do a great job.
Thanks,
Doug
Thanks,
Doug
The other question I have for you is what type of water picks/drives are on the boat? and what water pressure do you have at WOT? Thanks, Dean
Thanks,
Doug
Thanks,
Doug
