stellings
Re: stellings
Originally Posted by baja36ft
I Have 1 Pair Of Cmi Sport Tube. For Bravo Set Up.
Re: stellings
Originally Posted by awesomecat26
how tall are thease from the flanges to the centerline of the collector?
Hope fully you can understand this, (ROID YELLOW 15)
from the center line of the lowest row of bolts on the
flange is 20 inches to the top of the header. Also
from the center of the very last bolt on the flange on the
collector end of the flange....to the end of the the 4"
collector is 14inches.
(ROID DK.BLUE 12) from the center line of the lowest row of bolts on the flange is 22 inches to the top of the header. Also
Short tail pipes, two are 24inch long two are 27inch long.
Long tails pipes, one is 71 1/2 inch long the other is 74 1/2inch long.
Hope this helps
Cougarman
Re: stellings
Originally Posted by VinMan
Im lookin for a set for staggered motors. I believe they are black/yellows?
Re: stellings
Originally Posted by benspeed
What kind of boat? 3 of the 4 sets I have are out of a quad engine 50 Nortech. I don't think I have 2 sets that would work but maybe one. The ones I have were built in 01 and refurbished by Stellings in 04. I ran one set on the dyno once since then. 2k a set with tails
Re: stellings
Its a 32 Velocity/Thoroughbred. actually need the set for the foward motor. they are the ones that wrap up around the valve cover on the right side of the motor. The motor is on the left side of the boat.
Re: stellings
I think I've got what you need. By left you mean port? I've got a set of Blk./Lt. Green that measure 20.5" from center of collector to center of collector on a tall deck (10.200") with Merlins. The end of the Stbd. collector is 10.75" past the rear surface of the block. The port is 8" past. I can send you pics if you give me an e-mail to send to.
I'll check those measurements tonite.
Re: stellings
what is primary tube id? can you send dimensions for thease also ? from flange to collector centerline
IS 7 3/4 FROM COLLECTOR TO BOLT HOLE. HOPE THIS HELPS .
