No. 3, 4 & 5 SSM
Re: No. 3, 4 & 5 SSM
thanks NM, I'm curious on price for clean, used drive and gimbal....seems to be in good shape other than some scratches to the paint from lying on the ground....the shafts spin freely and there are no grinding noises....the gimbal has the lifting rams and hoses attached, also some scrathes from the ground......I would paint them anyways so I'm not concerned about the scatches......I need ball park figures to help me make the deal
Charter Member #40
Thedonz, you may want to pull some numbers off the drives and look them up to see what they are. Pretty good difference in value of a 4 vs a 5. The only external diff I believe is the depth of the skeg which I think is 1/4" or so shorter than a 4. The cav plates are the same. The front and rear pins for the trim rams are also slightly larger in dia on a 5 than a 4.
TeamShogren.com
Outerlimits
0
02-03-2007 08:34 PM
