Pitted gears in XR @ 75 hrs??
Re: Pitted gears in XR @ 75 hrs??
PM JC Perf on it, from what I have heard the teague shaft is the way to go, to make it even that much better.
This is pretty technical and boring reading , however if you read between the boring chit you will see the benefit of this type of surface treating on gears and such. This is the process we treat the EV8H stainless valves with in our heads and the wear resistence, strength, corrosion protection and the benefits are incredible and very inexpensive @about .50 cents per valve. I sometimes take a extreme duty (HA)stainless valve and one of our nitrided valves at a show and try to scratch the surfaces of each valve with each valve, current score extreme duty valve +100 scratches and some deep gouges, the nitrided valve 0 scratches. Ladys and Gentlemen we have a winner!! When people in the gear industry start using this process on gear sets exposed to high wear and loads, the days of the past will be no more. Just some real science that works!
www.finishing.com/kolene/qpq
Ray @ Raylar
Ray @ Raylar
Very interesting. I been using automatic transmission components (steel plates) that been thru this process for years. They rarely warp or get hot spots. I wonder what the average guy or even a small shop could do to get a set or a few sets of xr gears done,Smitty
Originally Posted by zt260
I just spoke to Dean at the Bravo Shop. They are using a new coating on the lower gears. It brings the surface hardness to 91 Rockwell. He offered to swap my lower gears out, so I'll give it a try.
On the bad run of2000-2001 XR gears I thought it was a bad run of pinion gears ??? Heard they were bad about loosing teeth
Rob
Contacts for QPQ nitriding
Kolene Corp 1-800 521-4182 ask for heat treater in your area with their process.
Bodycote @ (708) 344-4080
MMi @ (870) 236-6920
Hope this helps
Ray @ Raylar
Hope this helps
Ray @ Raylar
Originally Posted by Strip Poker 388
Dean has my drives now . I am buying his new cresant lowers with the new lower gears and I am trading in my uppers for the new HT's. I should be good and have a new 950hp 950TQ warrenty also
Rob
Rob
And are you trading to the BMAX HT with intergrated streering?
Originally Posted by Raylar
You guys might want to look into having XR gear set nitirided for added wear resistence. a lot of the big truck transmission building companies are now using this process with great results.
Ray @ Raylar
Ray @ Raylar
