Can a 572ci make 850hp na? under 6000rpm
#41
Re: Can a 572ci make 850hp na? under 6000rpm
Originally Posted by soinc
Rumrunner well your tuned in need to ask you which fuel (eletric) pump you recomend in a boat application that will suply my HP there is like 3 diferant pumps that flow 220 gph that you guys offer.
and dose a regulator with a return need to be run? with this set up?
thanks Shawn
thanks Shawn
Shawn,
Two questions for you first:
1) Can you run return lines back into your fuel tank(s)?
2) Do you need something USCG Legal?
#42
YES the tank has provisions fore return lines...
as for the COASTIES well lets just say they would no like my carbs...so Iguess I don't really care as long as it don't leak fuel in the bilge.
on another note we are trying a nother hyd roller more lift and dur I'll post how we make out thanks Shawn
#44
UP DATE from dyno runs as for the hr cam .647" & 262 dur. we made 795hp @ 5900 and 801 fpt @ 4600 anyone want these I have 2
the solid roller made 824hp @ 6200 & 799 fpt @ 4800 I still feel there is more there but we ran out of dyno time ( circle track motors need running)
#45
How about 555ci and 1050hp on 91octane. This motor was built to push a 21' pickle fork Jet boat. this motor did double duty at Ming for NJBA drags and the family ski boat. I know Dave (DNE costa mesa ca.) and he did a great job on Marty's motor and for others.
http://www.hotrod.com/howto/113_0206_1000/
#46
Nice numbers..! :drink What were your cam specs on the solid?
#47
Jdnca1 .718" lift 262 intake 272 ex 110 cl lash set @ .023 hot ...going by memory here I'll post the specs if they differ from cam card. there are some games played as the intake lobs are advanced ... I'm a bit disappointed hoped for 840 ish ...a tunnel ram would get us there but TOO much $$$
#48
15hp probably won't move the needle. Those are good numbers for a 572" single quad....nothing to be disappointed about! How is the idle on 110 C/L? I bet its pretty nasty...
#49
582cid 4.625bore, 4.375 stroke, static cr 10.75, dart 335 heads, edelebrock victor worked over by wilson, single blp 2.125 dominator, crane hr made 850 @ 6000 on chevron 92.
