Gear lube pump
#41
Looks like it may rain today...so no boating. Figured I'd finish my oil pump. I drilled out a shoulder bolt..put an o-ring on it..then drilled and tapped the other end with a 1/8th pipe tap, and inserted a short nipple. Put the quick disconnect ends on, and finished screwing it all together. I used a long shoulder bolt so that its easy to get your fingers around, and the knurling on the "head" makes it non-slip. The handle on the hose can be locked in the on position, and the quick disconnect will hold the oil in the lower unit till I'm ready to unscrew it. Sprayer is 2 gallons, and was $13 at Home Depot.
