trs drives blowing out props
Charter Member #927
Re: trs drives blowing out props
You might simply try a Mirage Plus instead of the Mirage. The plus has a lot more cup to it. Or try a Bravo 4 blade. If you are at 25" pitch now, then use a 24" 4 blade.
Charter Member #927
Originally Posted by mynov23
Mine are 23 pitch now
Well i had the mirage props recupped and added a little more .....still doing the same thing .....not as bad ....i havent tried my cleavers 23p yet .....any other ideas ????/
Make sure your tabs are all the way up. On my formula, if I had the tabs down at all they would lift the stern just enough that the props blew out everytime.
