Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 06-03-2006, 01:15 PM   #41
Re: Swapping my 454 with a 502 in a 22 Scarab
Does anyone know if a new flywheel is already at neutral?
Longrange4u is offline   Reply With Quote
Old 06-03-2006, 10:45 PM   #42
vandeano's Avatar
1992 Carrera
For what its worth this is the follow info on the flywheel I was talking about. Notice in Bold where is stats a neutral flywheel.
Brand: GM Performance Parts
Product Line: GM Performance Parts Flywheels
Ring Gear Tooth Quantity: 168-tooth
Rear Main Seal Style: 1-piece
Flywheel Material: Cast iron
Maximum Disc Diameter (in): 11.000 in.
Engine Balance: External
Balance Style: Neutral
Replaceable Friction Surface: No
Safety Rating: SFI 1.1
Quantity: Sold individually.
Flywheel, 168-Tooth, 11.00 in. Diameter, Cast Iron, External Balance, Chevy, 7.4L/454, Each
Check to make sure this part fits your application
The right flywheels for big or small blocks.
It's not important whether you have a big block or a small block, you can be sure that GM Performance Parts have you covered. They have high-quality lightweight nodular iron and billet steel flywheels to fit your needs, no matter what flavor of V8 interests you.
vandeano is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
454 To A 502? DURANGOKID59 General Q & A 11 07-28-2006 04:08 PM
502 or 454 ctadams21 General Q & A 1 03-24-2005 09:31 PM
454 vs 502 Elite Marine Pantera 15 03-11-2005 07:56 PM
454 or 502? formula454 Formula 7 08-11-2003 10:16 PM
Swapping from a 502 to a 496 HO mats General Q & A 13 10-27-2002 09:05 AM
Search Engine Optimization by vBSEO 3.2.0
