Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-18-2006, 07:01 PM   #1
RedDog382's Avatar
'99 Formula 382 Poker Run Special/'05 Formula 260 SS
Feul pressure sender fitting
Want to add a fuel pressure sender to the aft end of the fuel rail. Would like to keep my mechanical guage on the front end. Any ideas where to get a fitting to go from this to 1/4" pipe thread?
"ENJOY THE VIEW!"
RedDog382 is offline   Reply With Quote
Old 05-18-2006, 07:08 PM   #2
Toxic FORMULA
mopower's Avatar
1989 Formula SR-1 272 t/540's
Re: Feul pressure sender fitting
1/4" close nipple and 1/4" tee available at Home Depot(I know all to well) and probably Lowes
You can never have too much horsepower or money...It's just hard to have both.
mopower is offline   Reply With Quote
Sponsored Links
Old 05-18-2006, 07:13 PM   #3
RedDog382's Avatar
Sorry, this is a 1/8" fitting.
"ENJOY THE VIEW!"
Old 05-18-2006, 07:29 PM   #4
SORE MEMBER
Wobble's Avatar
Kawa 1100 ZXI, SeaDoo RXP Stryker Equalizer 2800
any speed shop should be able to set you up with earles type fittings probably #8 to 1/2 pipe then bushing from 1/2" to 1/8"
Mark,
Wobble is offline   Reply With Quote
Old 05-18-2006, 10:52 PM   #5
Toxic FORMULA
mopower's Avatar
Quote:
Oops . You're right , it is and so is mine
But like I said , any HD.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
496 Raw Wtr Pressure Switch brass fitting? Reckless32 General Q & A 0 09-18-2006 04:02 PM
Hyd Pressure Fitting Leaks LHC30Victory General Q & A 4 08-16-2005 03:46 PM
Help No Oil Pressure At Sender plumbers crack General Q & A 6 04-13-2005 08:09 PM
Water Pressure Fitting Size? shawn General Q & A 6 06-08-2004 11:13 PM
Water temp sender/Oil pressure sender? Danny_Ocean General Q & A 4 04-05-2004 11:47 PM
Search Engine Optimization by vBSEO 3.2.0
