motor break in woes...Help!!! >
Old 06-13-2006, 06:16 AM
tomas_wallin's Avatar
Default Re: motor break in woes...Help!!!
It really sounds like some starter issue like the rest already have told you. Since you ran the motor at 2k rpm's for about half an hour the break in SHOULD be ok. But - you never know...
tomas_wallin is offline
Old 06-13-2006, 06:46 AM
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Try turning the engine over by hand. If you can't I think you know the answer. If you can look at the starter. You said you used the same starter and flywheel from last year. Look at your oil. Any metal. Look at the filter any metal.
1BIGJIM is offline
Old 06-13-2006, 07:43 AM
I think when i get home from work i will pull the plugs and try to turn it over by hand...then well pull the starter and look for damage...I am worried becuase i have heard a starter break before and never heard it sound like this.
THanks for all your help guys...I will give an update later tonight.
tahoeguy318 is offline
Old 06-13-2006, 11:12 AM
fund razor's Avatar
That's what I was thinking too.
fund razor is offline
Old 06-13-2006, 11:41 AM
SB
Received 3,132 Likes on 1,409 Posts
If you have the older type 'Big Momma' starter make sure you have re-installed the front brace - holds other end of starter to block. If it isn't there, the starter can/will move and grindola. This is guaranteed !
SB is offline
Old 06-14-2006, 09:06 PM
MOP
My spare starter needs 3 shims, with out it sound awful the one on the engine has none and is fine. The front brace is very important on the old fat starters like I have, I found that just snugging the main bolts first then tightening the brace before final main bolt tightening gives me the best results.
Phil
MOP is offline
Ona-Mission
08-04-2008 08:47 PM
Dave98
Powerquest
11
05-13-2005 09:39 AM
BadDog
5
08-17-2004 08:42 PM
Treatj25
7
03-12-2004 01:35 PM
Mother
4
07-09-2002 05:12 AM
Quick Reply: motor break in woes...Help!!!
