Procharged small block, boom. >
Old 12-13-2006, 06:14 PM
  #81
Default Re: Procharged small block, boom.
Just got mine in today, they are 208/211, but .56 lift at .050 and 1.6 ratio roller rockers.
unbroken is offline
Old 12-14-2006, 08:59 AM
  #82
Originally Posted by bobl
This is the same cam Merc uses in the Scorpion 377, although it is fuel injected. I haven't had this boat in the water yet, but it idled pretty smooth on the dyno. Using it in a 350 will be a little more radical. I ususally use the next size smaller cam in the 350's. So much depends on the heads and desired operating RPM.
Thanks for the reply. I have a forged lower end, heads are AFR 195s with a Vic Jr below a Holley 750. I was spinning a 23p cleaver 5700rpms @ 70mph with my previous 360sbc which was around 400hp. I'm hoping the new setup should pull a little more. Not looking for much over 6000 rpms.
Ryan00TJ is offline
Old 12-14-2006, 09:16 AM
  #83
I did some research and it does appear Merc switched cams on the 6.2, from the ones you had originally. The cam they currently use has .465/.452 lift and 214/220 duration.
I will need to know what timing curve your builder wants in the ECM when you get your engines. They originally had fast burn heads that did not run a lot of timing. Since you changed heads, they probably will require more advance. It depends on the combustion chamber design.
bobl is offline
Old 12-14-2006, 10:08 AM
  #84
Hey Bob, motors are finished tomorrow, fully dressed out. SHould be seeing you in the next couple of weeks for the dyno and ECU calibration. I think we are all going to be surprised at the power. The compression is 9:1. HMMMM that would be perfect for whipples ehhh?
unbroken is offline
Old 05-04-2007, 12:54 PM
  #85
Ok, I installed the Crane 109831 cam yesterday and I'm having trouble getting it to idle. It will run if I keep the throttle slightly open, but if I bring it back to idle to quick it shuts off. I checked the idle air control valve and it is all the way open. Can I adjust the manual stop on the throttle body? Do I need to drill a hole in the throttle blade? Thanks guys.
Plane Silly is offline
Old 05-04-2007, 01:06 PM
  #86
Is that the Crane 222/230? That should be a nice compliment to your setup. It seems the engine is wanting more air at idle. I ran into a similar problem when adding a cam in my
LS1, the motor would run very rough and stumble and idle. For a quick fix I adjusted the throttle stop and it seemed to help some. I eventually drilled an 1/8th hole in the TB blade and that made a world of difference.
However, that is only a stopgap procedure until the motor was dynotuned by EFILive. After the tune the hole was no longer required and I filled it in.
Ryan00TJ is offline
Old 05-04-2007, 03:41 PM
  #87
Yes, it is the 222/230. Do you have to readjust the TP sensor if you adjust the throttle stop?
Old 05-04-2007, 07:22 PM
  #88
I'm kinda partial to the one I used in these 383's. It's a Crane 109831. I erroneously posted earlier that I had the 821 cam in these engines. If memory serves me right it's .509/.528 lift and 222/230 @ .050 duration with a 112 LSA. That's about as big as I would go. It hasn't killed my 02 sensor idling on the dyno, so I don't think it will revert water badly, although I do have Stainless Marine exhaust on it. The 109821 is a little milder and may be a better choice. I've had one of those running in a Whippled 6.2 for 3 years now. The 6 .2 came stock with the 104224 cam.
I used a Bullet Racing Cam 223/231/530/548 in my 383's they run great 69.8 on GPS in a 1987 272 formula.
formula 382 sr-1 is offline
Old 05-07-2007, 09:27 AM
  #89
Ok, idle problem turned out be an oops on my part. After I set the base timing I must have bumped the distributor because when I rechecked the timing it was off the scale ATC .
WHAT A DIFFERENCE A CAM MAKES! She ran just over 75 yesterday. That is a gain of 4 mph. There is still some tuning issues to deal with. Fuel mixture is 11.5:1(where I want it) at wot and 11:1 at idle(not where I want it). Looks like ASM will be getting my ECU back sometime soon. All and all I am very happy with the results. Thanks for all your help!
handfulz28
10-15-2006 02:25 PM
DKerns
5
09-05-2006 01:40 PM
z.zuperboat
Activator
22
03-13-2006 01:11 PM
chriscraft240
4
08-28-2003 01:17 PM
Da Patriot
44
11-24-2002 08:27 AM
Quick Reply: Procharged small block, boom.
