hydraulic lifter >
hydraulic lifter
hydraulic lifter
Old 07-21-2006, 12:37 PM
Default hydraulic lifter
Hi ! I have hydraulic roller lifters and high volume oil pump on my engine. I use Motul 300V Copetition 15W 50 oil and oil pressure is 70 PSI (idle) to 90 PSI (full throtle). Is there a risk that hydraulic lifters will work like solid ones ?
estonian is offline
Old 07-21-2006, 12:49 PM
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Default Re: hydraulic lifter
I guess I do not under stand the question.
That is some high oil pressure, are you running TIGHT clearences?
1BIGJIM is offline
Old 07-21-2006, 01:27 PM
BY U BOY's Avatar
I Think He Is Asking Since He Has High Oil Press Will It Affect Pumping Up The Lifter. My So No. I Would Also Just Use A A Single Weight Oil Like 40w.
BY U BOY is offline
Old 07-21-2006, 01:37 PM
SORE MEMBER
Wobble's Avatar
I agree, way high pressure, have you checked them with mechanical gauge? electric senders tend to read high as they get older.
Or a 0-60 sender hooked to a 0-80 gauge will read high also.
Wobble is offline
Old 07-21-2006, 01:44 PM
Rob
Strip Poker 388's Avatar
http://www.offshoreonly.com/forums/s...light=oil+pump
Strip Poker 388 is offline
Ken N
6
09-18-2008 03:42 PM
blownboat
2
02-26-2008 10:31 PM
ghittner
19
05-14-2007 05:36 PM
Bryan Rose
Prop Talk
3
08-24-2006 09:21 AM
BAD-HABIT
13
05-04-2002 12:02 AM
Quick Reply: hydraulic lifter
