Stroked 540cid - 650HP Eating Oil????  HELP!! >
Old 07-31-2006, 04:19 PM
Matty439's Avatar
Default Re: Stroked 540cid - 650HP Eating Oil???? HELP!!
Originally Posted by RaggedEdge
Matty 439 how are you making out in correcting this problem ? May have a similiar deal going with one of my engines now as well. Thanks in advance.
Installed the new PVC Valve and rebuilt the Carb as it was dumping an enormous amount of fuel at idle. Do not know if the carb was original problem, more than likely washing the oil past rings into the bottom end where it was burning it. I ran the boat for about 2 hours on Saturday and put it back on the trailer to fully cool. Out of town on business today, but will check the motor tomorrow. I will give you all an update!!!
Matty439 is offline
Old 07-31-2006, 04:21 PM
Matty439's Avatar
Originally Posted by baja36ft
when mine was eating oil it turned out to be the oil cooler the
oil was going out with the water easy fix.and i would not use
20-50 oil i use straight 40
Why would you suggest Straight 40?? What Brand?
Matty439 is offline
Old 08-06-2006, 07:08 PM
Matty439's Avatar
UPDATE - Problem Solved Pulled PCV Valve from base of intake and removed. Sealed intake port and carb line. Ran the boat 2 hours on Saturday, with W/O Throttle for a good run at 90++mph. Cooled motors and checked oil - OIL LEVEL WAS PERFECT & LITTLE TO NO EXHAUST BUILD UP ON SWIM PLATFORM!!!! My guess is this motor has no windage tray or it is pulling so hard with the big cam that the stock PCV Valve does not function correctly. I did switch to Mobile 15/50 Synthetic. Thanks for all the help from the OSO members!!!!!!
Matty439 is offline
Old 07-20-2012, 08:47 PM
hammerdown500's Avatar
I have the same issue on my new 500 efi clone. Any idea if this could be my issue aswell. I know it does not have a liftervalley trap installed was told by the builder that it was not needed
hammerdown500 is offline
Old 07-20-2012, 09:59 PM
you are having the same problem.... i ran across that last year on a friends 500's. the windage tray was left off the intake and it was eating oil like crazy. bad enough to foul the plugs every time we went out and ran hard. we left the pcv valve in the back of the intake but blocked the intake port and removed hose. not a drop lost since. try that and see if it solves your problem. that tray IS necessary.
88bullet is offline
Old 07-23-2012, 07:46 AM
SB
Received 3,102 Likes on 1,398 Posts
If you have a PCV pr crankcase vent in the intake, then the baffle is 100% needed to keep the oil from entering it. If the PCV is not in the intake, the baffle isn't totally needed but still prefferred in the sense of keeping hot oil from heating the intake.
SB is offline
Old 07-01-2014, 08:32 PM
Can anyone point me in the right direction for this baffle plate I can't find one . Part # anything. I understood that merc didn't use them so I didn't put one in
QUOTE=SB;3736544]If you have a PCV pr crankcase vent in the intake, then the baffle is 100% needed to keep the oil from entering it. If the PCV is not in the intake, the baffle isn't totally needed but still prefferred in the sense of keeping hot oil from heating the intake.[/QUOTE]
Old 07-01-2014, 09:24 PM
Mercury did install them in most all of their BB engines. As mentioned, you need one. I replied to your email saying that I may have one at the shop. I'll look tomorrow.
Eddie
Young Performance is offline
Old 07-01-2014, 09:43 PM
SB
Any GM Performance Parts place can get it for you. Probably Summit Racing too,
http://www.gmpartsdirect.com/perform...CATID=611.html
Part#12555320 - Manifold Oil Shield
Pic
SB is offline
Old 07-02-2014, 09:24 PM
Yep thanks guys that seems to have fixed my issue
Quick Reply: Stroked 540cid - 650HP Eating Oil???? HELP!!
