Blower motor air/fuel ratios
Re: Blower motor air/fuel ratios
Originally Posted by Strip Poker 388
That sound like a plan,does the afr meter have a record feature?
There are other AFR measurement systems out there with various cool features and I haven't decided on one yet. It looks like one is going to set me back around $400 to get everything I want. Ouch.
Originally Posted by Grog
The Innovate Motorsport LM-1 has an internal data logger that saves data recorded at about 3x per second (I think). It comes with software that you load on you home PC to look at graphically, and/or you can attach a meter to one of it's outputs to see AFRs real time. It will save up to 44 minutes at a time. The problem is that you have to buy the LM-2 (rpm converter) to look at AFR with respect to engine RPM.
That sounds about right,That is what Mark uses also.ya might ck with him on the thremacouple/sensor.Let us know what ya find out????
Rob
Originally Posted by Turbojack
When you log you are also going to need to record the map. That also comes into play if you are trying to program off site.
