Re: 502 MPI Leakdown test results
For a 502 and being cold that really isn't bad. They have a low tension ring package and not the tightest of pistons. Note: They are designed this way for good power and dependability.
Personally, I don't like cold leak down tests especially if motor has been sitting around for a while. A bit of crud or rust on vlave face / seats can dramatically influence (for the worse) these #'s where if engine is run these would disappear and engine is actually perfect.
Anyway - if a fresh water (or mostly) engine and no sludge and good maintenance, runs well, and good compression test, oh, and reasonable hours, then I'd have good faith in it.
Pretty hard to beat a Gen VI 502 hyd roller black Merc motor.
