Broken Rocker arm adjusting nut-500efi >
Old 10-20-2006, 01:37 PM
Rob
Strip Poker 388's Avatar
Default Re: Broken Rocker arm adjusting nut-500efi
Originally Posted by Fountain38
Wow,That's is exactly how my nuts cracked also.
Whats weird is a bunch of guys talking about cracked nuts
Strip Poker 388 is offline
Old 10-20-2006, 02:59 PM
Tricky919's Avatar
Originally Posted by Strip Poker 388
How many hours are on them and are you planing on pulling the heads?
270 hrs , and i wasn't unless i should..........
Tricky919 is offline
Old 10-20-2006, 03:45 PM
Wow, I appreciate tjhe reply. That helps alot. That is exactly how my nut cracked also. Do you have the ARP part number available that you used. Thanks
So the crack is about where the threading stops in the nut? And goes all away around?
cstraub is offline
Old 10-20-2006, 03:47 PM
If the springs are shot then this has allowed the valves to bounce and hammer the valve seats in the heads. If this has been done your just letting HP blow out the exhaust pipes.
Chris
cstraub is offline
Old 10-21-2006, 11:53 AM
Rob
It wouldnt hurt.Freshen the valve job ,ck guides,set up height new springs,maguflux for cracks,ck surface on the heads and block put some good fel-pros on it.
But if ya go that far I would rering and bearrings,its a never ending cycle !!!
mark30h
10
06-06-2010 10:34 PM
THRILLSEEKER
15
03-26-2010 07:52 PM
Rookie
11
05-27-2004 01:39 PM
THRILLSEEKER
8
05-05-2003 07:09 PM
88 MACH 1
08-11-2002 11:06 PM
Quick Reply: Broken Rocker arm adjusting nut-500efi
