XR drive
Re: XR drive
Call Marc at Bam Marine. Merc now makes a kit that has everything you need for around 85 bucks.
Charter Member #601
Re: XR drive
It depends on the input shaft ujoints. The new gimble bearing is offset by .050" and the trim limit spacers keep the drive from tilting too far when the old style large ujoints are in the shaft. I have not tried it with the new shafts, but the joints are smaller... So I would not go without the spacers until someone measures the clearance.
Hope this helps..
Dick
Hope this helps..
Dick
Canada Jeff
Drives and Lower Units
10
07-19-2007 02:38 PM
thayes11
0
10-02-2005 12:36 PM
Velocity Tom
07-16-2003 10:13 AM
panteraracin
3
02-07-2002 10:36 PM
