My 330 on Roids - Final Results
Re: My 330 on Roids - Final Results
I didn't think about that, yeah, he does like purple. No one will confuse my 257 with his 40ft Hustler though, even if he's not flying by at 110mph!!
By the way everyone, Tyler was a pleasure to work with. It's tough for a guy like me, who's used to the Dyno labs at GM where I've got access to every piece of instrumentation imaginable, to get work done in a small shop, but Tyler put up with me, and really made me feel at home.
Vary Nice Job Bruce!
You got more power with those L-29 heads than I would have expected. Are you using stock size valves?
You used the stock crank and Hypo pistons; what about the stock 3/8bolt rods?
Thanks for posting!
Thanks for posting!
Patrick
Patrick
Like I said, in retrospect, knowing all I ended up doing to it, I would have gone with a stroker crank/rods/piston kit, but hind sight is 20/20.
Yep, 257 powerquest. Looking to get upper 60's. I'd love to see 70 but that's probably a tick higher than I'll get. From what I was told, the boat ran 59 speedo (probably 56 gps) when the stock motor was new. No it's not a fast boat, but it's a nice first boat and I'm learning a lot.
So, what was the outcome?? What did you see on the water??
My 330 is currently torn down for a freshen-up, and I'm just making some mild modifications.
Cam suggestions would be helpful. I'd like to do a little something, but I'm not going crazy - I just want a good reliable motor.
I figure after I get everything done on this one and get it back in the boat, I'll start considering something wild to build up, and keep this one as a backup.
