best exhaust manifolds >
Old 01-24-2007, 08:08 PM
  #61
32storm's Avatar
Default Re: best exhaust manifolds
Originally Posted by Indy
I have 502s also, did you look at the EMIs? If so why did you go stainless over the EMIs...Thanks.
Yes, I also looked at the EMI's. Both have a 5year warranty, which is a plus. But, I liked the design of the mounting of the stainless riser to the manifold on the Stainless Marine better than the EMI. Also from talking to Stainless Marine, and seeing there brackets, I was confident that it would be a clean install. Throw-in to the mix, that I received a lot of excellent feedback on the Stainless Marine product.
I purchased the Stainless Marine from Fred at Trick. He had an excellent price on them at the time. I was on a tight time frame, as I was also installing a full hydraulic steering system simultaneously. The units shipped to me promptly, and no issues, or big surprises.
You can buy some other brands cheaper, IE: Revolution Marine. But, once you add in all the additional brackets for the fuel injection motors, it is not a huge price swing. Especially, when you factor in they have cast aluminum risers, and not Stainless Steel.
32storm is offline
Old 01-25-2007, 05:26 PM
  #62
Donzi502's Avatar
I mounted my filter on the hull. Just made a new oil line and mover it to the side. Better mounted off the engine in think. In fact i have pretty much moved everything i can off the engine, Less heat and viberation on the hull. Jas
Donzi502 is offline
Old 01-25-2007, 10:03 PM
  #63
JasonSmith's Avatar
http://www.offshoreonly.com/forums/s...highlight=dana
JasonSmith is offline
Old 01-26-2007, 07:38 PM
  #64
what do you guys think about the new danas coming out?
pol98xc6 is offline
Old 01-27-2007, 08:42 AM
  #65
Viper31's Avatar
Originally Posted by Lofty
One seldom talked about advantage is the servicabilty. Headers are easier to take on and off inside the boat. I can hold a header with one arm while I put bolts in with the other. It's also allot easier to change spark plugs. You can actually see them.
I believe Lofty has hit the nail on the head for those of us with side by side twin installs. The first time I changed plugs on a side by side twin with Gils it took me over an hour per engine and I had about 3 ideas for special tools to help make it easier after I was done. Maybe the mechs on this site can give us some pointers. My .02
Viper31 is offline
Old 04-03-2015, 02:45 PM
  #66
Do you still have the Rev exhaust system?
Baja272tyme is offline
Old 04-03-2015, 03:15 PM
  #67
8 year old thread. you are better off sending a pm to somebody than expecting them to re-read an old thread to see if somebody is trying to get hold of them. Even if they dropped off OSO completely, they probably still have the same email address.
dereknkathy is offline
Old 04-04-2015, 10:26 AM
  #68
Anyone have a set of aluminum manifolds and risers for 454 big block with captains choice exhaust for sale??? EMI, or Revolution Marine, or Stainless??? Text 413-374-3383
Old 04-04-2015, 01:13 PM
  #69
Post in wanted. Nobody wants to read 7 pages of 8 year old thread to see what you are looking for. Also search the swap shop. By the way. Welcome aboard. But please start a new thread instead of resurrecting extinct threads.
prostockcat
3
06-16-2008 07:33 PM
chaparral 2550sx
08-20-2007 01:08 PM
rssteiny
2
03-13-2006 11:54 PM
Andy
8
02-08-2004 04:12 PM
excaliber
4
09-15-2002 12:47 PM
Quick Reply: best exhaust manifolds
