crankshaft .0025 from front to rear ? >
Old 01-25-2007, 06:54 PM
troc's Avatar
Default Re: crankshaft .0025 from front to rear ?
This forum is pretty handy isn't it
cort
troc is offline
Old 01-25-2007, 07:39 PM
MarineKinetics
rmbuilder's Avatar
This may help:
Attached Thumbnails crankshaft .0025 from front to rear ?-clearances1.jpg   crankshaft .0025 from front to rear ?-clearances2.jpg   crankshaft .0025 from front to rear ?-clearances3.jpg
rmbuilder is offline
Old 01-26-2007, 01:42 AM
Rob
Strip Poker 388's Avatar
Most BBC ive set up I try to get .0025-.003. the last time around eben had some in the .0032.saw no ill effects .
Most of the engine builders Ive talked to say the same on a high hp motor ot blower motors.
Strip Poker 388 is offline
Old 01-31-2007, 08:25 AM
I've read that torque converters expand with excessive heat and cause clearance problems in this area. Could there be more heat and "twist" on the crankshaft near the rear?
vtec is offline
Old 01-31-2007, 11:15 AM
troc's Avatar
Bill after some more checking,and remeasuring I decided to regrind the crankshaft, cheap insurance.
p.s. the difference in my shop when the heater was blowing on the engine stand and when it was colder overnight was .0002-.0003"
troc is offline
Old 01-31-2007, 11:35 AM
Rob
Originally Posted by troc
talked to machine shop today,same explanation as you Bill. rear is usually under .001-.002. larger bearing surface to support crank/oil for thrust surfaces. he did say he would not
run clearances greater than .035 in a bbc. I bought a set of .001 over bearings and split with std. and got my .025"
Thanks again Bill
cort
Remember thicker bearing is supose to go in the upper whem using diff sizes.
So you got it to .0025 and still ground the crank?
Old 01-31-2007, 02:49 PM
troc's Avatar
Yes i still ground the crank. there was almost .0008 difference
between journal 1 and 4. Machine shop said it makes no difference where thicker bearing is placed, what is your logic?
thanks Cort
troc is offline
Old 01-31-2007, 06:43 PM
H2Xmark's Avatar
remember if you grind the crank you are taking out the surface treatment. factory steel cranks are nitrate hardened
H2Xmark is offline
Old 01-31-2007, 11:43 PM
Rob
thanks Cort
Think about it .Wouldnt you want the thicker bearing on the top ,thrust side ? Its in the Clevite tech bulletin.King also.I also double cked and called a tech at ACL.
Like H2Xmark said ,and making it weaker being smaller.You also have less to choose from in bearing on a 10 under crank.
best of luck
Rob
Old 02-05-2007, 05:18 PM
troc's Avatar
thanks rob ,will check it out.
troc is offline
Quick Reply: crankshaft .0025 from front to rear ?
