Question about dry exhaust???
Charter Member #601
I agree, you are in trouble.. If she doenst like loud, your done!!
As far as the size of the dump, years ago I built my own tail pipes. Ended up with a spacer (1/4") between the inner and outer pipes, then I cut three slots about 3/8" wide, equally around the pipe. So there was one slot at 12:00 o'clock and one at 4 and 8 o'clock. Never had any problems. Later I had CMI build my tails this way, with the inner pipe about 2" longer than the outer. Now I clamp on a set of 4" Borla mufflers, and the water is dumped in front of the mufflers. Pretty quiet and takes the edge off. But people can still hear me. The water police dont bother me.. And the jury is still out on wheather or not I am leaving HP on the table. I have made one pass without the mufflers and seen no gain in speed. Just made an extreme amount of noise.
And again.. your in trouble.. she will need some serious noise protection. .. good luck!!
Hope this helps.. D*i*c*k
Greg, The motors are 525's and are suppose to be quiet. I want to be there when you start the daytona with the new pipes, Kate will want to ride in my quiet boat. Good luck. Doug
That's exactly what I'm afraid of! And if mine is louder than yours I'm going to shoot myself...that is if I can beat Kate to it.
I hate the winter!!
Too Loud
My New 598 With Drys Litterally Will Set Off Car Alarms In The Boat Launch At 75 Feet Away When It Fires Crazy Loud Goi Ng To Add Cmi Soun D Eliminations This Year For Sure !!! But It Sounds Awsom For A While . Plus You Wont Hear Youre Wife Telling You To Slow Down !!
[QUOTE=grads2112;2020585]Why would you put a bung in it and plumb it throught the hull? Now I'm completely confused. The water is going to dump through that hole and thats it.[/QUOT
with such a large hole on the bottom of the tail , as well as the 1/4 weep hole, your transom depending on how far the pipes stick out, will infact get burned. the porpose for the bung is to plumb the exiting water over board.without creating a fit problem due to the bung not fitting thru the transom. dry means dry. many people attempt this with some sucess but end creating other problems such as burnt transoms and reversion issues or even burnt valves.
good luck
good luck
Sorry I didn't see this thread sooner... I personally wouldn't wand dry again. I love loud, but the dry is really an unpleasant loud. My buddy GL with his wet 900's is very loud but low pitch and perfect. And perhaps it's just my application because I have no other experience, but my dry had a very unique high pitch loud that was tough on the ears.
I'll look for videos...
