Drive Question: 28ft / 5300lbs / 750hp - Would a Bravo XR work?
Racer
Racer
The gear treatment is one of the many things that needs to be done to a drive along with every other possible upgrade. Its not going to keep stock parts from catstrophicly failing.Their are numerous upgrades that need to be done to get any kind of real life out of a bravo drive,no way around it,they are not cheap and sooner or later it will still break,especially in a racing enviroment. If a guy is starting with a clean slate and is going to spend some serious coin ONCE, start with something stronger if your goal is all out ,trouble free racing, a few wot passes around a lake and cruising don't compare to non-stop abuse that racing puts on parts,Smitty
Racer
Racer
Smitty thats the first pick I ve seen of the twisted shaft whos was it?
rob
That was a max worx shaft after 10 or so wide open passes with a 5 blade 28 maximus I tried on my boat.The shaft was 5 seasons old and never had the slightest indication of damage even with the 32 pitch 4 blade,the 5 blade was just too much and was torque loading the boat. It was a std dia billet shaft they were making before the xr stuff even came out,you would thiink it would have broken were it is smaller but it didn't,the xr style billet max worx shaft I replaced it with is no bigger in the spot were it broke so I am staying away from 5 blade props.The lower gears however still looked like brand new from the cryo/polish treatment which is a good sign that it is going to help greatly extend the gear life,Smitty
Kaama,the max worx shafts are made out of a exotic alloy that can twist somewhat and return to its original state without breaking,it goes thru a exstensive treatment and is sold to them by the inch,I feel the torque my motor makes vs the dia/strength of the shaft compounded by the overall gear ratio (around 1500 ft lbs) exceeded the shear point of the shaft when I added a huge prop with virtually no slip. The cryo treatment process stabilizes the grain structure in a common metal like 8620 steel (it is soft with a hard surface like a egg shell),the polishing and treatment process makes the surface where the oil film/contact (or pinch point) comes together less likely to gall so its not whats needed to make a shaft under a severe torsional load stronger. My 960 ftlb tq motor puts the same amount of stress on the prop shaft when using 1.50 gears that a motor making 1100-1150 ftlbs would with 1.35 or 1250 ft lbs with 1.26 gears would to keep things in perspective,large 5 blade props are the quickest way to guarentee failure on a bravo drive,Smitty
I know you had troubles with the 5 blade, and I understand your point. I just think there’s more to 5 blade bravo failures than that. From my experience the trick is to maintain some slip. If your hull runs great with a 4 blade at say 12% slip I would not recommend a 5 blade unless you plan to raise your propshaft an inch or two. But if you’re at 20% slip, and can barely get on plan with a 4 blade than a 5 blade could work out great. I added a 5 blade Maximus and a 2 " shorty and picked up about 7mph. Granted its a Bmax, but I have broke propshafts with 4 blades, and since the switch I have not broke another. Now I know I just screwed myself.
Dave
I hate the winter!!
Smitty,
Dave
Dave
So I will restate what I said-if a boats given set-up runs a 4 blade prop with a high slip number and likes it and your drive is staying together with serious power,its going to come apart if you drop the slip considerably with a 5 blade if your already right on the edge. Everytime I see someone selling a pair of max worx drives and they are bitczhing they only held up 10 or 20 hours,they usually have a picture of them on their boat with 5 blade props. To run something like a maximus it definately needs to be cut down or real high so it has some slip,Smitty
