Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-17-2007, 06:38 PM   #1
2012 Nothing w/0hp
2" Livorsi mechanical water pressure gauge
Anybody know the size fitting on the back of the gauge. I would like to run a different line than the plastic one supplied. I want to order the gauge and line/fittings at the same time so hopefully they will arrive around the same time
jdub is offline   Reply With Quote
Old 05-17-2007, 06:40 PM   #2
Elite Marine's Avatar
Should be 1/4" NPT
Elite Marine is offline   Reply With Quote
Sponsored Links
Old 05-17-2007, 06:43 PM   #3
2012 Nothing w/0hp
Thanks, also is it male or female on the back of the gauge?
Old 05-17-2007, 09:36 PM   #4
Male - you can get brass ones from your local hardware store or Home Depot. Or you can get SS from Mcmaster Carr or Grainger. Should be 1/4" NPT x 1/4" Barb or you coud go to AN fittings.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Electric or Mechanical fuel pressure gauge ? Rocko C General Q & A 2 07-27-2007 10:26 AM
Livorsi 4 5/8" DataTach/Prop Slip Multi Gauge tpmarine.com New Products and Member Discounts 7 06-28-2007 03:14 PM
Livorsi 4 5/8" DataTach/Prop Slip Multi Gauge tpmarine.com New Products and Member Discounts 5 04-03-2007 04:46 PM
mechanical water pressure & intake manifold pressure/ boost gage Zanie General Q & A 5 03-10-2005 11:58 AM
water pressure gauge treatcg General Q & A 2 05-22-2003 10:26 AM
Search Engine Optimization by vBSEO 3.2.0
