leak down test proceedure?
what is the best way to perform a leak down test. i have all the guages but have heard of two different ways to do it.
id like to check mine, just in case, but i need to know the proper steps to take to be accurate.
thanks
b70
thanks
b70
been doing some reading....
should rockers be loosened so both valves are closed? i assume so.
piston should start at TDC and then fall to BDC when psi is applied correct?
b70
b70
