Timing chain oiling on dart big M block
MR, I don't remember exactly, I think it was .003 on mains and rods. When I built the engine, a long time marine engine builder set it all up and I remember him saying that it had to be "loose". He even had what my wife would call a really "cute" little bore gauge that he checked each valve guide bore with and made sure that there was proper clearance between stem and guide. I used canfield heads and several of the guides needed to be loosened up. Anyway, I think the clearances are all correct for the marine use it was built for.
My question is about the oil pressure issue, I really do value the help from you seasoned engine builders, THAT I am definitely not! My oil pressure, as I said starts out at about 100 psi but if I run it hard for 5-10 minutes straight, it starts to drop. I've seen it go all the way to 30 psi. Gen 6 block, at first I thought it was the oil bypass in the pad. Changed that to the 30 psi bypass valve, no change. I thought that maybe the high oil pressure was causing the oil cooler and filter to be bypassed. At this point I am wondering if I should just go with a standard volume pump. Is there a reason to run high volume and pressure in an engine that only spins to 5500 rpm? As I posted before, I would think that a high volume and pressure pump takes significantly more hp to turn at 5500 rpm. If they aren't needed, why use them. Can I use a standard volume and pressure pump? What advantage does high oil flow give you?
Also, you said you were using DART blocks. I have never seen a genVI Dart BBC Block. THey are set up like gen IV. Do they make a 1 piece seal block?
High volume is good because of the length of time that the engine runs at high RPMs. 5500 for extended periods is actually pretty high. You don't need high Pressure. If you can get the guage between 60-80 you are just fine.
Where is the oild pressure at idle?
3 thousanths should be fine for crank and rod clearance. That is plenty loose.
Good luck.
patriyacht, yes and to double check it I used an infrared temp gun, stayed a little cool at about 180-200 deg.
jeff1000, no offense taken at all I'm greatfull for the help and input. I did check oil line routing, I run to the oil filter first and then to the cooler. Not a dart block, Gm gen 6 block with one piece main seal. At idle COLD, it will peg my 100 psi oil gauge, idles at about 850 rpm. Where can I get an 80# oil spring for the melling pump? Part number would make it really easy, Thanks for all the help so far!
You can call Melling and ge their advise if you wnt to rebuld. The whole pump is only around 100.
I gave some thought to your problm earlier.
What weight oil are you using? I didn't see it earlier.
If you are using multi weight it might be heaing up and be to thin for your bearing clearances.
Try runnung straight 40 weight for a little while and see if the presure range changes a little. It might not drop as much after it heats up. If that is the case, then it might just be about running the right oil. I need to read back on this thread and see if thi has been discussed all ready.
Jeff1000, I use gold cap mobil 1 oil, 15-50. Have not tried a single weight oil, I can try that, but this winter, I have my engine out anyway and figured I'd try and correct this problem while it was easy to change everything. I may just buy a new oil pump, but the one in the engine now only has 50 hours run time on it and I was hoping a new pressure spring might just solve the problem.
airation, drop oil level 1 qt , see if this helps , just a thought , although when i got my 598 first back , id loose oil pressure just as stated , verry frustrating tryed everthing . ended up sendin g engine back to find out they didnt clearence the pan gasket enough and the crank caught the gasket and sucket it into the pump , thus causing the oil pressure to be great cold . but would run to 30 psi before id shut her down , dislodge and then suck back in , DAM I WAS PISSED , lost whole summer and was very frustrating too , good luck
Smitty,
So what is the problem?? You have great oil pressure, bearing clearence is perfect, and your worrying? I would run Pennzoil 25W50 racing engine oil with those bearing clearences. It would be ideal to see 80-85 PSI , but 100 will not hurt you. I run 165 psi oil pressure on blown alcohol applications. Oil pressure is your friend. I do not agree with your .050 hole theory. Your going to bleed off a ton of oil.
In the past (before this dart block)I used 20w/50 kendall (I know its no longer as good as it used to be) or ran mobil1 vtwin 20w/50 and ran straight50 wt if running in real warm water on vacation. I have never had any bearing problems,everytime I have freshened/rebuilt my 540 they looked like new (120 hours or so) but I'm not trying to get 200 plus hours out of it either,Smitty
Nova 26 I would agree oil aeration. High rpm running for long periods of time require good oil control. A deep Dooley oil pan. windage tray and a scraper are what I'm using along with the high volume oil pump. This is what I'd like to get. http://www.billetfab.com/index.htm 100 psi at cold idle is nothing to worry about.
Patri and all the others, thanks for all the input, I think my next step will be to replace the stock 6 qt oil pan with a 10-14 quart pan. Anybody have one for a gen 6 block cheap?
tomas_wallin
7
05-26-2005 02:06 AM
