Borg Warner 71C Limitations >
Old 06-19-2007, 02:26 PM
You could stay with the 71's if you expect 500-600HP. They can handle this by adding two more clutch plates. I raced 8 years with this set-up with 500-525HP...never touched them again. BAM would be a safe choice for the upgrade. Mercury used the 71's (red tag) with the 370 TRS package.
BenPerfected is offline
Old 06-19-2007, 02:46 PM
CIG3's Avatar
BAM is the best and in your area. Quick turn around too.
CIG3 is offline
Old 06-20-2007, 05:46 AM
Big Block Billy's Avatar
Post
That's right. Go to Marc at Bam. They have a one of a kind transmission dyno and are the experts...
The 72 has bigger internals and may consume more HP to run. But is an excellent piece.
You could do all kinds of things including installing brass tank clutch plates, even if you warp them, the trans will finish the poker run or race, but be stuck in gear, but get you home.
What the shops do is surface grind the steels to allow for more plates to increase the co-efficiency of friction ( surface area) and try to drill oil passages out to make clutch pack work faster and reduce slippage in engagement.
This is also done by modifying pumps.
Yes , I've been inside of a few transmissions too. BBB
Big Block Billy is offline
Old 06-20-2007, 05:48 AM
Post
Originally Posted by Swamplizard
Thanks guys - the current set up has a 1" spacer between the trans and the drive shaft so I might be okay without moving the motors. The 72C can handle 450hp I think per the spec sheet.
Can it beefed up a bit somehow/somewhere if I want to run another 100 HP though it?
Can it run in both directions (one counter rotating motor) or is it two different models I need?
Just spin the pump around. It has arrows on it.... BBB
Old 06-20-2007, 08:26 PM
If needed i am in orlando and know how to work on these. If you want to order the parts i would be happy to work on them for you. email me at [email protected]
NorTech50 is offline
Old 12-30-2008, 08:54 AM
if you decide on getting different trannys, let me know when you are going to sell the 71c. [email protected]
keywesttony is offline
Full Force
Swap Shop
29
09-08-2009 12:44 PM
THRILLSEEKER
6
03-14-2008 10:30 PM
IRONMAN
1
08-01-2006 10:39 AM
Horsepower
4
06-12-2004 10:51 AM
KenP
6
01-12-2002 01:37 AM
Quick Reply: Borg Warner 71C Limitations
