Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-28-2007, 01:20 PM   #21
Activator 30, MERCURY Racing EU 662 SCi, NXT1
..here another Picture from my 28,
here you can see the fitting above the extension box
Bad Influence is offline   Reply With Quote
Old 08-28-2007, 01:47 PM   #22
Liquid Fix's Avatar
Thanks a million BI. That's what I needed to see.
Thru-hulls are on order......
Thanks again, LF
Liquid Fix is offline   Reply With Quote
Sponsored Links
Old 08-28-2007, 02:46 PM   #23
hi marcus,thx man! is this just plastic thru hull fittings on both ends?
BIG SLICK is offline   Reply With Quote
Old 08-28-2007, 03:24 PM   #24
Hi BS,
the originals where plastic at transom and brazen at the notch.
I replaced the fittings after my personel experience without this vent by
stainless steel fittings.
See also pic attached
Old 08-28-2007, 06:31 PM   #25
Hi BI,is the hole in the pad in the center of the pad,towards the front or towards the transom?thx !!
Old 08-28-2007, 06:32 PM   #26
very nice boat by the way!
Old 08-29-2007, 04:02 AM   #27
Hi BS,
the fitting is in the center to the keel,
and because clearance problem´s with the oil pan
I replaced it a little to the tramsom.
Work´s great !
Marcus
Old 08-29-2007, 06:53 AM   #28
the Flightmaster
Wild Card 09's Avatar
`03 Baja 25 Outlaw, 600 SCi
I would expect that the best place for it is as near to the front of the notch as possible (towards the bow) but as Marcus explained, he has moved it further towards the transom after installing the 540, and it still works fine.
On the picture shown he had not yet refitted the fitting and pipe, which is when he found out what it was there for!
It would be good to know what diameter of fitting and hose has been used, as I think the larger the better!
Stephen Murkett
`03 25 Outlaw, HP600SCi,
XR upper, Imco 2" shorty lower
Imco 12" x 3" extension box
& full hydraulic steering
EMI 24" tabs,
labbed Bravo 32"
Wild Card 09 is offline   Reply With Quote
Old 08-29-2007, 09:34 AM   #29
Quote:
Hi Steve,
I followed your recommendation "bigger is better" and
used 1 1/2"
Marcus
Old 08-29-2007, 10:43 PM   #30
Liquid Fix's Avatar
Bad Influnce or Wild Card 09,
How thick is the hull at the notch? I'm trying to get the correct length thru-hull on order. Thanks, LF
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Aero-tek Boats gofastwannabe General Boating Discussion 35 06-08-2011 10:22 PM
Daredevil : Aero-Tek Photos Wardey General Boating Discussion 0 04-20-2008 07:18 PM
cavitation problem walkintheplank Prop Talk 1 09-11-2006 10:12 PM
Aero-tek ernie davis General Boating Discussion 0 08-24-2004 03:47 PM
Aero-Tek information xtremeracingf1 General Boating Discussion 5 09-24-2003 08:50 PM
Search Engine Optimization by vBSEO 3.2.0
