GPS Speedo Install ?
JB Marshall
I am looking to replace the current water pickup speedometer with a GPS speedometer, the question is can I connect the GPS speedo into my current GPS antenna or do I have to mount an additional one?
Thanks,
JB
Thanks,
JB
you can use the gps antennae you have allready, i believe its the blue wire , nmea it should be labeled. you can try calling livorsi and ask for todd. he's a great guy and can probably help you if what i mentioned doesnt.
good luck,
good luck,
Charter Member #927
That is what I did and it works great. I was thinking it was the brown wire. Whichever,you have to make sure they are confgured the same.
