What Causes Blower Motor Surge
JE, I'll look at whipples web site....Are you familiar with the valve ?
Thanks, LE
PS: We have found a highly engineered valve for holding vacuum on a dry sump motor. Kind of a must have. Might work for bypass on the blower.
Thanks, LE
It does sound cool but it's rough on tranys' and drives, depending on who's on the sticks.
Ron Potter has a good set up, his motors don't seem to surge nearly as badly as most.
AS to the root cause, I'll leave that to the engine gugrus'.
Geronimo36
I have zero surge with only a slight hunt when shifting into neutral but that's normal for a blower motor.
The surging is caused by fuel puddling in the intake. The line that goes to the metering block is most likely a boost reference line...this has been done for years.
