Surface Drives, Why NOT????
SeaRay Sundancer
Any staggerd engine v is going to more difficult to dock. Each prop is pushing and pulling too close to the centerline of the boat to swing you around very fast. I would be telling the same people to be careful behind my six boat as my asd boat....gawd i wish I had one to bark at people about. My wife managed to mangle her toe plenty bad on a stock B1 prop.
What I got out of the thread is the boat was fast, had to drag tabs and it also had a wicked chine walk in the video and zero information about how the boat handled at 0-100 MPH what it was like in turns or got on plane. Plus no information on all the "little tweaks" that were done to the boat.
That thread only raises more questions than it gives me answers.
we are installing a set of asd7 in a 38 formula in seattle if any body wants to go for a ride. just give me a call john at eastsideoffshore 425 822 5300 we flew to Cal and ran them and were sold they work great ! no more blown drives !!! they turn tighter than my #6 and have you ever tried to swim next to them? the drive has no sharp points !! the props are the same.
Never understood where the docking thing started... The Arneson boats that I've been in dock just fine, maybe it's the driver? As far as safety goes well, are props duller when you put them on #6's? I personally don't let kids, adults or anything short of a cat jump off the back of my boat. Safety is a huge issue around these boats, they're not jungle-gyms.
Registered User
Depends on the boat. My Express cat backed up wonderfully. My hustler 32 might as well have not even had a reverse gear. Reverse was a joke- it had 3 settings- forward, neutral and "other".
Registered User
I've only owned a couple of surface drive boats and have never put the drives on a boat that wasn't rigged with regular outdrives. I have though owned alot of boats and have done alot of experimenting. When Rik says you need no special hull, I take that to mean you can bolt them to any transom.
In my own experience, I've taken a good running boat and slowed it down and/or made it handle poorly simply by adding something like extension boxes to the existing drives. I've seen boats that handle poorly, porpoised badly and in one case would almost not plane simply from a prop change. Now maybe you can successfully adapt an Arneson to any boat but what would concern me is the knowledge base- how many people have done EXACTLY what I'm looking at doing and done it successfully. If you have the resources ($$$) to do the experimenting and have a real desire to do something like this, then maybe they're a good idea. The biggst downside is prop availability and expense. Not everyone is going to be able to let you try their props to zero in on a setup.
