Questions I bought the Raylar kit and headers in the classifieds
We did the dyno work with Raylar on a 496 converted motor with our exhaust. The Raylar kit brings the engine up to roughly 525 HP. With the Dana Exhaust the engine made 555HP and 602 ft lbs of torque. The torque curve was incredible, at 2500 RPM's it was over 500 ft lbs, and through 90 percent of the range it never dropped below 550 ft lbs.
The gentleman that sold all this to me did dyno his set up. He also did the ECM upgrade. He was making 565HP on the dyno. Don't know about torque. He did say Raylar thought reversion would be a problem with the stock exhaust.
I am not sure I need to max the engine out. I am more interested in the holeshot and midrange. Extra topend is a plus though. The pachanga will be my wild ride! Either exhaust system should help my pachanga and 1/2 way keep my budget inline!
Another concern I have is the ECM upgrade raises the rev limiter to 5450 RPM's. Will the 496 handle the extra RPM's with reliability on a stock bottem end? It's a 2003.
Never Enuff
I've talked to Ray on a couple of occasions and he has always been very good to talk with and very helpful and I haven't bought anything from him yet. It's worth a try--all he can do is hang up--and I doubt that--he's a good guy. The product still has his name on it.
Jay
Jay
Even used Raylar kits are popular !
Pachanga:
I think you will be very pleased with the Raylar kit you purchased form Lee. With stock 496 exhaust the kits make about 595 ft/lbs of torque on a stock block 496 and about 605 to 610 Ft/lbs on a 496 equipped with the Raylar kit and a true header/manifold system like the Dana exhaust. As for Rpms, the weak link in a stock 496 is the valve train. with our specially equipped aluminum heads, with special springs retainers, lightweight valves , roller rockers and cam you have in the kit the 5400rpm limit will not be any problem! Enjoy!! If you need a set of installation instructions let me know.
As for the Dana exhaust not fitting on a 454 or 502, that is not rue. the cylinder head exhaust configuration and dimensions on all three are the same. You would just not need the Dana 496 engine kit but a standard equipped set.
Raylor, Thank You very much for your reply! So am I OK to run the factory 496 exhaust with the kit? Lee seemed to think there might be a concern about reversion.
Lee is sending the installation guide! Thanks for the offer. Is it OK to reuse the Rockerarm nuts?
The 496 headers are a nice low cost upgrade vs the stock 330 manifolds. Not huge performance gains but better looks, less weight and a little better flow.
http://www.offshoreonly.com/forums/s...d.php?t=126168
Pachanga:
Don't worry about reversion on the stock exhaust. It will not be any problem. There are over 100 owners like yourself running the kit with stock exhaust for a few years now and never had a reversion problem. The headers will raise the horsepower to about 560HP but even then reversion will not show its ugly head!
Good Luck and Have fun!
Regards,
Ray @ Raylar
Regards,
Ray @ Raylar
