ls2 heads
Old 01-23-2008, 03:37 PM
bor
bor's Avatar
Originally Posted by Ryan00TJ
Very true but I believe a L92 head would be too much for a stock cube 346 LS1 with their big 260cc intake runner. The AFR 205 head with its 205cc port can support power well past
7K rpms with the right combo. I would use the L92s on larger bore motors like a 383 or 402 or bigger.
youre right the requere a minium bore of 4.000" because the have big valves and the valve angle,so you can NOT use them on a ls1
bor is offline
Old 01-23-2008, 03:42 PM
Amm
Is anyone making headers or exhaust manifolds for these LS engines? How about starters and other marine accessories?
The rumors seems to indicate this is the last year of the 496. And with these:
http://www.gm.com/explore/technology...LY6_Marine.pdf
http://www.gm.com/explore/technology...LS2_Marine.pdf
...it does not seem like the LS is going to have problems making lots of power.
Amm is offline
Old 01-23-2008, 06:58 PM
Thanks for those links. I did not know GM was moving that way with the LSX engines. As for power they can make it!
My LS1 has a basic heads and cam package and makes
420rwhp @ 396rwtq which is around 475 hp at the crank out of 346 cubes. A friends 402 LS2 with AFR 225 heads and cam makes 567rwhp @ 521rwtq which is well over 600hp at the crank. He traps 130+ mph at the track to my 117.
Ryan00TJ is offline
Old 01-24-2008, 06:07 AM
fastlane40's Avatar
Great info guys.I think more people will be using this setup.Thanks for all the help.
fastlane40 is offline
Old 01-24-2008, 02:33 PM
bor
bor's Avatar
about the headers a orderd a pair of cmi headers after calling them ,the tell me the fit .
about the rest marine acc.I ll get mine engine this week and then I look but it s based on the bolt patern of a 5.7 so the bellhousing must fit ,but when I have it I will post my results here for the raw waterpump I have a serptine driven mercruiser oem maybe have to made some mods but c ant be much but I ll post it all .
by raylar the also did it but don t know what heads they used had tried to call them serveral times also send e mails but no results but that s a very nice looking engine (lsm 550)
bor
bor is offline
fastlane40
5
01-29-2008 06:31 AM
calndux
05-17-2007 10:32 PM
Hang Time 27
7
07-03-2006 07:46 PM
iamfaster
3
01-08-2005 06:48 PM
Dave1972
6
12-09-2003 02:16 PM
Quick Reply: ls2 heads
