Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 02-13-2008, 11:22 PM   #1
86 Wellcraft Nova 23
how can you tell the diffrence?
Between a regular 454 and a 454 mag, i have the black cap that goes over the carb, but it dosnt have any thing on its just plain black, the previous owner really didnt know just knew it was a 454
there any like special serial numbers or ways to tell with out having it dynoed
jlaudio29 is offline   Reply With Quote
Old 02-13-2008, 11:55 PM   #2
thanks for the info
Sponsored Links
Old 02-14-2008, 09:21 AM   #3
1989 Chaparral Villain III
Pull the valve covers and check the head casting numbers.
ECeptor is offline   Reply With Quote
Old 02-14-2008, 09:51 AM   #4
ENFORCER24's Avatar
1988 251 convincor with a BBF , yea a 460 ford !!
Look at the intake runners , mag will be squared off and you cant see much of the head where the intake bolts up , non-mag has peanut port heads and you can see alot of the intake face side of the head , just for grins , look for the red sticker on the starboard (driver side) valve cover , if it says its 330hp its non-mag , 365/385 and its a magnum
ENFORCER24 is offline   Reply With Quote
Old 02-14-2008, 10:09 AM   #5
Current Obsession
BY U BOY's Avatar
91 Scarab 21' Excel/1999 Proline 200 sport
Quote:
Originally Posted by fredefox View Post
Mag has 4 bolt main bearing caps and the non mag has two bolt main caps.
Thats not true, I have a 330 and it was a 4 bolt main.
Just above the starter there should be a plate with the serial number on it.
Post that # and im sure someone can look it up for you.
IS THAT BAD
My favorite color is clear
CAJUN COWBOY
BY U BOY is offline   Reply With Quote
Old 02-14-2008, 11:15 AM   #6
Agreed, I have a '96 7.4L and based on the block casting number, 10237297, it's a 4 bolt main. The biggest difference between the 7.4L (454) and the Mag is forged crank (and rods, I think), large port heads (rectangular GM vs. small port oval GM, both are cast iron) and tall intake.
mjw930 is offline   Reply With Quote
Old 02-14-2008, 11:29 AM   #7
Quote:
Don't forget cast vs forged pistons...which are the weakest link in the 7.4.
Old 02-14-2008, 01:19 PM   #8
thanks for the replys guys ill have to check it all out, i dont store the boat at my house anymore so ill have to check it next time i see it.
Old 02-16-2008, 09:01 AM   #9
KAAMA's Avatar
A boat?....What boat??? How about a galvanized warsh tub wit a tornady strapped own da rear!
I'm pretty sure the Merc 330hp/454cid originally was designed with a 2-bolt main block with all cast parts. It was in the late 1980's or so that the 330 came with a 4-bolt block vs a 2-bolt, but still had cast parts.
Thank God for the U.S. Marines!
Hey, I'm still learning! ;)
KAAMA is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Diffrence? 7.4L vs Mag bobo1 Scarab 2 10-15-2008 07:03 PM
DIFFRENCE BETWEEN A BRAVO 1 and 2 thayes11 General Q & A 2 10-21-2005 05:10 AM
What's diffrence between HP500, 502, 509 and 540? TELLefant General Q & A 12 05-19-2005 12:59 AM
26 OR 31 How Big a Diffrence in Ride? sonic31 Sonic 16 02-23-2005 07:02 PM
Atachment photos Question diffrence? Strip Poker 388 General Boating Discussion 1 02-20-2003 08:09 AM
Search Engine Optimization by vBSEO 3.2.0
