Engine guru's/ fuel injectors
RBeyer... those are some nice heads. Will make great power with a blower especially with good port work!!! I figured that the 2.5 was a typo.
But I do have to agree with GPM on the fp. I run that much fp on my turbo alcohol car with 35-39lbs of boost.
I have tried two different regulators and tested at the rail and the gauge same results. This is my concern I think we are at the end of these nozzles for this appliction as I think we are forcing fuel thru them.
Bob
I run Fast EFI, I was told injectors are rated at 43.5 psi, you need roughly .5 lb per HP. Running high pressure would act like a bigger injector. There is a calculation for what you are doing. I believe you can find it on Kinsler Fuel Injection. Without knowing the duty cycle at top end there is no way of telling how close you are to static.
Found this info on FAST's website. Looks like you need bigger injectors IMHO.
Supercharged v8 peak power:
55lb/hr = 660hp
60lb/hr = 720hp
65lb/hr = 780hp
83lb/hr = 996hp
This comes with this note:
NOTE: fuel injectors in and of themselves do nothing to produce power, so don’t choose a larger injector because of the peak HP rating of the injector –too large of an injector will only waste fuel and hurt your throttle response, much like overcarbureting a non-injected engine-. Select the right injector to support the power that your engine produces -you’ll never run out of fuel, and you’ll experience great throttle response, a smooth power curve, and good fuel economy.
55lb/hr = 660hp
60lb/hr = 720hp
65lb/hr = 780hp
83lb/hr = 996hp
55lb/hr = 660hp
60lb/hr = 720hp
65lb/hr = 780hp
83lb/hr = 996hp
55lb/hr = 660hp
60lb/hr = 720hp
65lb/hr = 780hp
83lb/hr = 996hp
Like GPM stated, I think the base is 45psi to start. I run 48psi on my car as a base, but I also run alcohol and the fp boost ratio is 1:1. So with 30lbs of boost, I have almost 80psi. But mine is also a turbo, but boost is boost right?
