Quote:
Originally Posted by My Addiction
My dad is having his redone and I was suprised to see it did not have a roller cam. Is this right?
That is correct. They used a Hyd flat tappet cam on these motors. Most of them were from Crane with a .559" Intake and .578" Exhaust valve lift. Have his engine builder measure the cam lobes and see what numbers he gets. With the new oils out there without the zinc additive, you may be really surprised to how much wear there is on the lobes. Make sure he goes with a nice roller set-up on the rebuild. He can run more aggressive on the lift. Depending on which exhaust he is running, He may want to stay around the 112-114 center line on the cam. I am running a 108 centerline on mine, but also semi dry exhaust. and even with 25" dry/wet tailpipes, I still worry about reversion at a idle. With alittle work, you should be able to get 600+ hp out of these motors easy. They were built with all the good internals and were built to run. Take a look at the back casting "# on the block. It should be a 14044807. This will let you know that it is a Mark IV Bowtie block that they used on the Bulldog. Like the other post stated, There are alot of people out there that want to say that they have the Bulldog package, but are really just HP 500 ( 502 ). Good luck with your build..
