Eratic Gauges
I just started to have this same problem on my port motor, at around 3500 rpm the port tach will flutter 500 rpm or so, both motors run strong fire good and clean burn, seems like the plug wires make the best remedy to correct this problem, mine is a 95 with 500 HP's, what wires would you recomend for best performance and least amount of interferance ? as well as best fit.
