Help With Prop/bow Lift?!?!?!?! >
Old 05-14-2008, 01:20 PM
Question Help With Prop/bow Lift?!?!?!?!
guys-
i'm having a major issue with my boat turning low rpms at the top end, and getting basically NO bow lift while on plane! can someone please help me out? i've got all the details over in the "Prop Talk" forum. thanks for any help you can offer!
BILL
http://www.offshoreonly.com/forums/s...d.php?t=186682
that should be my other post on it!
Freeryd is offline
Old 05-15-2008, 07:29 AM
what engine prop combo are you running ? also need to make sure the boat is not water logged....seen it before, if that comes up, find a place where you can weight the boat and trailer, sunbtract the trailer weight and ck against the original weight. also engine down on power ?? good compression etc ?? lots of things to consider..not enough info yet...Rob
ezstriper is offline
Old 05-15-2008, 05:32 PM
ChristianGott's Avatar
same question as ez...
what motor/prop/drive specs? could be over propped...that with low hp/torque would account for the inability to pick up the bow....
i did that a couple times trying props on my 24....
whoops..replied before checking out your link...doing it now...
checked your stats...the replys seem on the money..try merc's prop selector, or bammarine's link...?
Propeller Recommendation(s) (based on merc's prop selector and your data)
Stainless Steel 4 15.250 22.0 RH 48-831910A55 bravo
Stainless Steel 3 14.625 23.0 RH 48-13704A46 mirage
Stainless Steel 4 14.625 23.0 RH 48-857030A46 revolution
fun stuff, huh?
hope this helps..
c
ChristianGott is offline
Old 05-15-2008, 05:40 PM
check out the above link and it'll take you into the other thread where everyone's filling my head with ideas! a few more can't hurt!
Freeryd is offline
Old 05-15-2008, 06:01 PM
You could call Throttle Up ...............
Kidnova is offline
Old 05-15-2008, 06:32 PM
Rookie's Avatar
Received 1,207 Likes on 580 Posts
As others have stated you are over propped. 23" mirage will help you get maybe 400 rpm to 4700. The prop slip calculator puts you at 9% which is incredible for that hull and non-worked prop. Are your speeds gps and it your totally accurate?
I also thought that Baja put a little bit of hook in their hulls to keep them handling better, which would keep your bow down.
A 24" Bravo1 in reality is a 23". Bravo 1's are know to be about 1" less than what they are stamped.
I don't believe that you are going to be gaining much speed when you do find the right prop, but it will get you out of the torque band and be easier on your engine when your running at the top of the horsepower band.
If everything is correct with you #'s, I think a 22" Bravo one will be your best all around cruising prop and worked 23" Mirage+ will be your fastest prop.
Rookie is offline
Old Navy
Prop Talk
22
08-05-2008 04:24 PM
PARADOX
04-28-2008 11:30 AM
Pure Energy
Prop Talk
3
07-19-2006 07:35 PM
OffDuty
11
05-26-2004 07:34 PM
BadDog
5
11-01-2002 07:31 AM
Quick Reply: Help With Prop/bow Lift?!?!?!?!
