Quote:
Originally Posted by Budz Motorsports
A leakdown is a very accurate way to check valves and rings. We have done a few hundred leakdowns here and I have never heard of doing a leakdown in three positions! .
Had a motor down on power once. Turned out that on two cylinders the spirolocks had come out and scored the walls. The walls weren't scored up top though. Doing leakdown at TDC wouldn't show it. Doing it where the damage was done told us right where to look.
You also can't gauge bore wear very well by just doing it at TDC. The piston moves fastest at 90 degrees of crankshaft rotation and as such, more wear occurs in the center of the bores. Add in that the Chevy doesn't exactly have long rods and rod angles aren't optimum and you're definitely going to find ovalled bores on anything with hours on them. Again, leakdown at TDC won't tell you that you have several thousandths more ring gap at mid-bore.
The best part is it only takes a moment once you're already set up on the bore.
