Racing Oil Filters
#31
I wonder if wix makes some of there filters.
I remember researching the Wix fuel water seperator/filters and some of the #'s they had someone else make them for them, cant remmber the names, I asked why the said it was cheaper on them if its a # that they dont sell that many of
#34
#35
http://store.summitracing.com/partde...p?part=FRM-HP1
Fram's HP Series filters are just for performance and racing use. The spin-on filters can trap very small micron-sized particles that cause most engine wear. All filters have an anti-drainback valve, with a maximum flow rate.
The new Fram HP filters now filter down to 18 microns!
Brand: Fram
Product Line: Fram HP Series Oil Filters Part Type: Oil Filters
Part Number: FRM-HP1
Oil Filter Style: Canister
Height (in): 5.750 in.
Outside Diameter (in): 3.719 in.
Filter Bypass Relief Valve: Yes
Relief Valve Open (psi): 22 psi
Anti-Drainback Valve: Yes
Smallest Particle Filtered: 18 microns
Maximum Burst Pressure (psi): 500 psi
Thread Size: 3/4-16 in.
Gasket Outside Diameter (in): 2.813 in.
Gasket Inside Diameter (in): 2.422 in.
Gasket Thickness (in): 0.328 in.
Quantity: Sold individually.
Brand: Fram
#36
So what size particle will hurt a motor? 18,30,50????
How small is a 30 micron particle?
I would think fuel dilution and combustion gas is manly what hurts oil, after the initial run in of the motor{ring seal/cam breakin} that the particle/trash/metal wear is minimal unless something is going wrong?
#37
#38
It's significant if the particles are present in large numbers in an engine's oil. It's like liquid sandpaper.
Combustion byproducts and gasoline blowby along with metal particles are why changing oil frequently makes a lot of sense along with a good oil filter and oil.
If you have 20W-50 M-1 V-Twin and a M-1 or Wix filter on the engine and are changing the oil every 25-30 hours you will see a diference in extended life of the engine that will more than pay you back for your efforts.
#39
For those who might be interested, a NAPA Gold #1794 is a tall 2 qt. Wix filter with no bypass. Combined with a high volume oil pump, large oil lines and fittings and a plugged bypass in the block, I see no restriction at all from the oil filter.
