Detroit Diesels
Detroit Diesels
Anyone know anything about the two stroke 6v-92's?? We have one that is blowing a lot of black smoke and seems to be down on power.
Have had one suggestion of a possible air intake restriction that I have not checked out yet.
Any help would be greatly appreciated.
Charter Member #927
That would be the first thing I would look at.
If it was fuel related you wouldn't have the black smoke. Unless it's way over fueling, but that doesn't happen on it's own very often.
Thanks for the input. A little more info from me. 1995 model 6v92 not electronically controlled with less than 600 hrs.
Will check for air restriction this weekend and go from there.
they have numerous thing that cause that, bad injector,exhaust leak(crack in manifold which is common) had a freind with a pair of them fought that issue for years !!! and still is as far as I know...
It's located in the blower inlet housing which is on top of the blower where the turbo compressor outlet connects. It should have a small lever on the side and a latch. The flap inside the housing is spring loaded closed. Cock the lever back against the spring pressure and lock the latch to hold it open. These were used on mechanically controlled engines as an emergency stop in case of an injector, linkage, or governor problem that would prevent normal shut down by moving the injectors to the stop position by the stop lever.
