Leaking KPM sea strainers ? >
Old 07-20-2008, 07:15 AM
Nauti By Nature's Avatar
Default Leaking KPM sea strainers ?
my kpm sea strainers are leaking from one of the windows
in the cover . Has this happened to anyone? Can it just be
resealed better with silicone or is their a better fix , or does it need replacing ? purchased them thru trick marine
Thanks Howard
Nauti By Nature is offline
Old 07-20-2008, 07:41 AM
Are they new? Leaked from day 1 ? Or older ? The salt gets into the cracks and crevises the seperates the seals a bit. Mine leaked dont know what brand it was off hand. I took mine out and totaly apart. Cleaned everything. Reasembled with some grease on the rubber O rings and now she no leak. I even put wing nuts on to open if it get filled. They had nuts on the top. So evn hand tight it dont leak. Hope this helps.
z.zuperboat is offline
Old 08-04-2008, 06:43 AM
Thanks Howard
Hi, this is not a problem that is common.
What size of strainer do you have? if you send a photo of the offending article I am sure that we can get this sorted out for you.
Re-sealing will not be possible as the lexan is bonded to the aluminium with an epoxy and is devised to work up to 200 psi.
Regards
[email protected]
avonboatingltd is offline
Old 11-06-2008, 01:43 AM
thanks for writing back ! they are the second largest size
I forgot the volume though .
thanks Howard
Old 11-09-2008, 09:19 AM
Default Re Leaking Strainer
Hi Nauti, if you measure the diameter of the strainer itself and email it to me, I will be able to get it sorted.
[email protected]
regards
Pete
Oceanpete is offline
ratman
09-11-2006 08:28 AM
Anarchy Powerboats
10-18-2005 07:06 PM
ratman
08-14-2005 04:21 PM
NEVRENUFF
06-14-2002 12:05 AM
Quick Reply: Leaking KPM sea strainers ?
