Boat would start but stumbled and quits??? >
Old 07-30-2008, 06:52 PM
ok, got the low water pick up muff, and hit the key.. boat started first try......but the motor is not getting any water. I pulled one of the hoses going tothe manifolds and nothing. so i am thinking the empeller came apart, and them otor got a littl hotter than normall ona hot day and caused vaper lock. it now starts buyt needs an empeller?
thoughts?
mittens is offline
Old 08-12-2008, 01:38 PM
empeller was GONE, put new one in,, motor gets watter now, but will still not run, fuel pressure is only 20 when you hit the key. you can play with it, and get it to 38-40 and it runs. but will not keep this up...
put new pump, fuel redulator, and cool fuel system in. pressure is still low, 10-15....fuel filter is dry.....will putting gas in the filers fix it?
mittens is offline
Old 08-12-2008, 01:45 PM
Try here: http://www.teambajamarine.com/forum/...ad.php?t=15047
emilsr is offline
Old 08-12-2008, 07:37 PM
Received 1,811 Likes on 901 Posts
Fill the fuel filter with fuel and try it again. Chances are, you have a lot of air in the fuel rails.
Griff is offline
Old 08-14-2008, 08:21 AM
Ok so i filled the filter and got pressur, and it ran for about a min. then dropped pressure and started same thing. I found out that the fuel line going from the pressure regulator tot he fuel filter was kinked, and leaking at the fitting a little. so i am assuming that if i fiz the kink and get the fitting tight so no leaks that the pump will then be able to suck new fuel into the filter and keep the pressure up?
thoughts?
mittens is offline
Old 08-14-2008, 10:02 PM
That could easily cause the low pressure. You may have just saved yourself an explosion as well.
Griff is offline
Old 08-22-2008, 07:15 AM
New hose, and got the leaks to stop and the kink is gone, FIller filter up and let it pump the system up about 3 times and when i tried starting it ran fine. Boat is in the water and ran for me yesterday as well.. have big plans for the weekend with all working. THanks for the help
mittens is offline
SOFPilot
Do It Yourself, Boating on a Budget
0
06-13-2008 04:35 PM
Anarchy Powerboats
SBRT
43
12-02-2005 01:16 AM
Strip Poker 388
07-29-2003 06:05 AM
Lucididee
11-29-2002 04:19 PM
Quick Reply: Boat would start but stumbled and quits???
