Instruction for Sea water Pump HP 500
Hey guys I would like to change my sea water pumps on my engines my self for the 1st time. The engines are 1999 HP 500 carbs. The pumps are the water pump fuel pump combo on the front of the motors. I was told due to the age that I should get the kit from mercruiser the is the impeller with the black plastic housing & metal wear plate. It looks
Fairly simple so I started by removing the 2 water hoses & then removing the 4 bolts
From the back housing. Before I break some thing I thought I would ask here. The black
Housing does not want to just pull off & I don’t want to crack it. How does this come apart & am I missing something? Thanks guys.
